Odd normal smoothing error?
Jahun
Post by Jahun »
Hmm.. just made a simple setup to test a few things.. but it goes wrong right away.. :|
So I got this scene and the main light is a bit behind and to the right of the camera. When I have all materials to say 80% diffuse and all the rest off, I get this:
As if the normals are exactly the wrong way around or so :|
When I tick "double sided" in material editor I get:
If I tick "smoothing" too, I get this result: (which is more or less similar when double sided is turned off btw)
Which actually makes sense.. is this a known bug? I couldn't really find it somewhere. I am using 1.7 OB 5, have viewport on shaded solid or similar and tried a bunch of other stuff..
I can live with putting all materials on smoothing... but am wondering if it is a problem with my scene or a known issue..
florian
Post by florian »
Never had any error like this one. Which LW Version are you using? Can you upload the scene for us to test?
Cheers, Florian
Jahun
Post by Jahun »
Ah sure, and the version is 9.2
Can't really figure out what's going wrong...
Kraytest.zip
Scene and object file
(25.96 KiB) Downloaded 242 times
florian
Post by florian »
Sorry but I cant reproduce the error here (with LW 9.3). My renderings all look correct. I noticed that you have the maxwell plugin in that scene. Maybe this is causing the error? I dont have maxwell so I cant test this.
Cheers, Florian
Jahun
Post by Jahun »
Hmm thanks for trying... I haven't figured it out yet.. made a new scene, uninstalled Maxwell and tried some other stuff.
I'll live with it for now then untill I get some more time to put into this..
