excerpt from Lightwave manual:
"PLD takes information about how the edges in the scene fall onto the lattice of output pixels. The pixel lattice is then deformed and realigned to best represent the underlying geometry. This generally helps with edges in images and textures. One limit to this method is that it cannot reconstruct details that have not been sampled at all, such as highly undersampled data. The advantage gained with PLD is that it gives you an image with some level of antialiasing without the need for extra samples being taken."
images rendered in kray without antialiasing, rerendered in lightwave with 1 pass pld (krayaliased front projected on a polygon no pixel blending no mipmap)
results are not the same when using the image as background image (notice thin lines)
also the results seem to be the same whether front projecting the kray aliased render on the corresponding actual geometry or on a simple polygon
post antialiasing with lightwave (PLD)
- kray aliased render
- krayaliased.png (118.86 KiB) Viewed 5059 times
- rerender in lightwave front projection on polygon no mipmap no pixel blending antialiasing 1 pass pld
- pld1pass.jpg (92.09 KiB) Viewed 5078 times
- krayaliased2.png (306.46 KiB) Viewed 5094 times
- pld1pass.jpg (212.03 KiB) Viewed 5067 times
- rerender in lightwave as background image antialiasing 1 pass pld (notice thin lines)
- pld1passbkg.jpg (206.54 KiB) Viewed 5079 times
Interesting approach aombk - thanks for the comparisons. On a slight side note - I've been mucking about with LW 9.2OB antialiasing for a while and found that the quickest and most painless method with the new AA/AS/MB combinations seems to be the age old trick of rendering at a higher res (and low relatively low AA settings) and scaling down your image. At this stage I've noticed that the new AA does seem to have issues resolving fine deails.
