Make a random color or material in Kray instance?
				azman_821009
Hi everyone,
Actually I don't know how I want to explain. Can I make a random color or material using Kray instance? For example a tree, I want to used a Kray instance for clone a lot of tree and in the same time I want to make a random or different color/material of leaf etc. Hope you guys know what I'm trying to say.
Anyway sorry for my English.
Thanks.
Azmen
Thanks.
Azmen
Re: Make a random color or material in Kray instance?
Wait for Jure´s answer. I think this is possible in LW x32 ...azman_821009 wrote:Hi everyone,
Thanks.
Azmen
Well there is not an easy one click solution for this yet. But there are couple of options you can use:azman_821009 wrote:Hi everyone,
Thanks.
Azmen
1. "Use color" option in Kray Instances will allow you to colorize the instance with the templates color. For this to work your template points must be at least 1-point polys so that they can have material applied.
2. You can create a map where you paint certain areas different color and apply this as a planar map over your whole instanced area (must be applied in world coordinates mode).
3. use nodes to get variation between instances.
2 in the list is what I have been doing.
				azman_821009
How you did for this option? Can you show me and explain step-by-step.vpii wrote:2 in the list is what I have been doing.
Thanks.
 Azmen
				azman_821009
How can I turn OFF the instance I made? I've try to turn it OFF on 'Objects Properties > Geometry .....' and also on 'Kray Instance > Enable Plugin' but it still appeared.
Thanks.
Azmen
 Thanks.
Azmen
Two ways:azman_821009 wrote:How you did for this option? Can you show me and explain step-by-step.vpii wrote:2 in the list is what I have been doing.
Thanks.
Azmen
1/ by points (You have to create points as poly)
2/ by wire (normal wire or better, Subpatch)
Both you can setup with texture (very important "world textures coordinates" and Y direction" Just put texture for clone surface and in plugin Instance select option for take colours.
				azman_821009
Thanks.
Azmen
Thanks.
Azmen
This does not workazman_821009 wrote:How can I turn OFF the instance I made? I've try to turn it OFF on 'Objects Properties > Geometry .....'
This should work correctand also on 'Kray Instance > Enable Plugin' but it still appeared.
Thanks.
Azmen
				azman_821009
Yes but it still appeared. Tried many times both options.
Do you have any idea?
Azmen
Azmen
Turning off "enable plugin" should work. Check again.
If does not work reinstall Kray plugins , please (maybe You have some old mixed with new)
				azman_821009
Yes, i turned it off many times. Then tried to delete/removed the Kray Instance plug-in on Object Properties > Geometry > ... it's work.jure wrote:Turning off "enable plugin" should work. Check again.
So works? If not please delete all Kray.p from disk (by searcher windows as: "kray.*") and put all new Kray plugins in one folder.
				azman_821009
Thanks again Janusz. Finally it works.Janusz Biela wrote:So works? If not please delete all Kray.p from disk (by searcher windows as: "kray.*") and put all new Kray plugins in one folder.
 1 more thing, I tired to make different color the point (light and darker green) but when I rendered, nothing happen with the colors.
Thanks.
Azmen
