Hi there!
Let's say I have a scene I am happy with, with several cameras, and I would like to render all them over the night...
Will I be able to render several cameras, same frame, with a single instance of Lightwave openend?
I know this is doable in Lightwave but, can this be done in kray?
Cheers
						Rendering several cameras with a single button hit
Re: Rendering several cameras with a single button hit
You can do it withe screamernet. RenderQ I do not recommend because it has a bug.
Just have to ask why different cameras on the same frame? Can't be one camera on different keyframe?
I rendered several camera angles and zoom values last night. One camera positioned over a few key frames. Make the zoom value stepped.  Works perfectly fine.
Well, every camera has a different lense so different position or rotation... It will be great being able to use the plugin to render several cameras with a single hit that Lightwave has even if the different cameras are on different frames as the plugin is able to do.geo_n wrote:Just have to ask why different cameras on the same frame? Can't be one camera on different keyframe?
