hi to all.. I have found some crashes rendering in hi-res images (4000x3000)
(using half resolution everything goes right)
I'm using standard medium kray presets with no caustics on a pc with "just" 2Gb of RAM
do you know wich kray parameters should be fixed to avoid that? the scene is very simple...
thanks
Alberto
						hi res crashes
				albertos2008
Re: hi res crashes
Only help You more RAM....or butterflyNET TRIAL (You save memmory becouse You don`t need Lightwave)albertos2008 wrote:hi to all.. I have found some crashes rendering in hi-res images (4000x3000)
thanks
Alberto
				albertos2008
Re: hi res crashes
thanks johny..
yes I was thinking the same.. I have to buy extra ram...!
I'm currently using BNR on a 5 node little farm (and it's crash anyway..)
this night I will try the useful splitting feature..
thanks...
thanks...
Re: hi res crashes
Or virtual render (TrueArt)
Re: hi res crashes
albertos2008 wrote:thanks johny..
thanks...
IMHO Kray very good work with minimum 8 Giga RAM....
